Hi everybody. I just finished on this Friday my trasnission swap from auto to 6 speed. to my 1996 supra turbo I put everything NEW, from Champion Toyota (jeff watson) and an RPS carbon carbon Chromoly flywheel. Anybody who wants to do it and need a hint can write to me. I did it by myself with a friend
I have a couple of questions that I can't answer myself because in my country there are no more supras.
- First strange thing.... The isolation of the outside noise is poor compared when my car was automatic... specialy in the zone of the gearbox and starter.
Now the starter sounds louder inside the car when I crank the engine... even with the clutch pressed to avoid noise coming from the gearbox. The cranking sound is much louder inside.
I have checked and recheched if there is any hole on the subtunnel, or something like that... but nope. I also but all the rubber isolators from the shiffter as any other stock supra.
Does anybody konw if the automatic supra is really more isolated than the 6 speed?
- Second... the gearbox sounds a LOT. I know that when an aftermarket flywheel is used insted of the stock dual mass flywheel the gearbox starts rattleing at idel.. bla bla.... but my question is the folowing: Is it ok the transmission sounds even most of the time when you are driving??? (when I say sound, I mean gear noise, not harmonic sound) in my case it sounds until 2300 RPM, above that the sounds stops. But under 2300 RPM it makes a lot of nois, on every gear 1, 2 ,3 ....6
It also makes lots of noise when you lower the gear (from 4th to 3rd at high speed)
I ask this question because I bought the chromoly flywheel which they told is not noisy as the aluminium, but in my case there is a lot of noise.
Could it be someting bad inside the transmission (even though it is sopoused to be new)
The transmission came full of oil, I also bought the 2 quarts of V160 oil, but I haven't put it since it allready has new oil in it.
- Another issue, I switched to the 6speed tach, wich doesn't have the PRNDL indicators. Well.. I installed it and it has 400 RPM of positive offset (my RPM cut whent up to 7200 RPM with the new tach) is that offset consider in the range of normal offset????
The rest is ok, the car feels great, the clutch incredable. How much brake in should I give to it?
Andres
Andres
