I swaped an Aristo 2jzgte and purchased these parts...
You have an auto trans,and depends if your motor is from Aristo or Supra
NEW TOYOTA PARTS
-7m oil pressure valve (for the gauge cluster)
-1jz bellhousing
-1jz oil filter bracket (for the block)
-1jz engine mount brackets
-2jz throttle cable
-2jz PS reservoir
-2jz upper & lower front sump oil pan with buffle
-2jz front pump oil strainer
-2jz oil strainer plug & gasket
-2jz oil dip stick and tube
-2jz coolant and radiator hoses
-2jz front & rear crank seals
-2jz vacuum,pvc,intake hoses
-2jz thermostat
-2jz mechanical water pump
-2jz radiator fun,coupling and pulley
-2jz timing belt and accessories drive belt
-2jz cam gears seals
-2jz flywheel bolts
