my suggestion is to wait for the analysis, and if they say its "ok" i would slap some new oil in it, and then drive it around for about 20 miles and then drain it again...
this time when u drain it tho, grab a CLEAN empty drain pan, something you can visually see into, and then grab a white piece of paper and hold it under the stream of oil...if you see any type of Alaskan gold rush...i would plan on yanking the motor and pulling the oil pans off to see whats going on with your bearings...if it passes the paper test, just visually look into the oil, you should see some type of metal flake to the oil for a brand new motor, not extremely gold tho.
brand new motors break in, just the nature of them, you will see larger pieces of metal from ring seating and smaller pieces, the engine builder could have built the motor somewhat tight, it just depends, do you have a blueprint or a build sheet of this motor?
hope this helps,
Ben Y
