1 - 15 of 15 Posts
Well my MKIV is in the body shop getting a color cahange and some other things done. I thought hey while it's there might as well have it lowered since I just got some new wheels and tires. Well they installed my Eibach's and KYB's but instead of lowering the car I now have a good 5.5 to 6 inch wheel gap in the rear, it looks ridiculous. I don't know what the front looks like yet since the wheels are off and the front end is in the air because they are painting my frame and firewall. I got my springs and shocks from one of the advertisers on the forum and I am positive I got the correct springs and shocks. I know it could not raise this much purely becaues of alignment. I called the shop where I bought my parts and they said that even if it were possible to install everything backwards there is no way the car could raise that much. So my question is what could they possibly have done wrong to make my car lift instead of lower. Please help me guys, it looks ridiculous.
Heavy Metal Momentum
Springs take some time to settle, I think mine went ~6 mos. before they settled to the advertised height. If you're now using a shorter sidewall (actual tire OD less than stock) this will also make the fender gap larger. 5-6 inches sounds like a 4x4 clearance, are you sure they didn't have the rear still in the air?
You need to lower the car completely before we can make any assumptions. depending on where the car is being lifted it might be taking more weight off the rear than you think.
I'm running a 315/35/17 in the rear on 17 x 10in. wheel. The car is being lifted sort of on the sides of the tranny and is missing a lot of parts on the front end right now. And the rear is on the ground.
Highway Demon
i agree with that.. wait untill the car is completely planted on the ground for atleast a month to make any final asumptions as to anything being wrong on the car..
Well thanks guys, I guess I'm just being paranoid. I'll just have to wait.
www.ziptieracing.com
you are running a 315 on a 10" wheel?
Yes, and it looks and fits great.
i have no experience w/ KYBs but is it possible the shock body has a collar u need to remove? i know some oem shocks have a collar there to prevent bottoming out during transportation but it will make the car look raised until removed...
quick said:
Isn't that rim far too narrow based on the tire recommendations?
ed zacary.
Discussion Starter · #12 ·
mifesto said:
i have no experience w/ KYBs but is it possible the shock body has a collar u need to remove? i know some oem shocks have a collar there to prevent bottoming out during transportation but it will make the car look raised until removed...[/
I will have to check that next time I go later this week.
I think you just answered your question right here ^
That goes double if the car hasn't been rolled a least a couple of feet after installation.
Discussion Starter · #14 ·
I just went down there today and we leveled the car out. Turns out I'm just an idiot. It looks great on the new springs.
haha, well hey no problem.....At least that's good news! :D
1 - 15 of 15 Posts
