barelymkIII said:
I'm planning to start with a blown engine car (or shell, depending what I find) and do a mild build from there. My goal is somewhere in the 300hp range.
I'd strongly recommend that when you do get one and build your motor, go ahead and do whatever internals you've got planned but set the car up as if it was otherwise basically stock and get it running with stock fuel and boost on the factory ecu for a little while just to make sure everything's behaving properly, then bolt on your external mods once it's fully broken in and you're satisfied that all is well. It'll save you a lot of headaches when it won't start, won't idle, runs like crap, etc, etc... If you can get it started and running right on stock fuel/boost with the stock ecu and it holds up through the break-in then you know you're off to a good start.
I've seen so many people buy a non-running MkIII Supra, tear it apart, do all sorts of big mods, drop it in, and they give up on it out of total frustration when it either won't run worth a crap or won't even start even after they screw with it for weeks or months.
Back in 2007 I saved a friend's MkIII from getting parted out or sold as-is after a major rebuild by helping him get everything he needed to put it back to totally stock externals and finally get it running after helping him get past his total frustration with it all modded up and fubar.
After the break in and a few thousand new miles of enjoying his low 14's "stock" MkIII Supra the modding went back on successfully and he still loves the car.
Doing that's not necessary but it saves a lot of frustration, especially if you've never done it before, and especially when you're new to modding Supras.
:lol::lol:
SOMEONE read into that signature a little too much.
I was just sayin'...
From what I read of the post itself, considering he was a MkIII owner who no longer has it, I was making an observation and passing on some long-term personal experience that contradicts his sig.
Keep in mind that if that's the only MkIII he's ever owned and that's the problem he happened to have with it, he may think that's a common problem with the 7M powered Supras even though it's not.
Also, others who don't know may see that sig and draw the conclusion that 7M's in general tend to have bearing issues, which they don't.
So for those who don't know and happen to see his sig or stumble onto this thread there's a bit more of a real-world reference now.
Plus although it's a little more involved than just bolting on an intercooler, full exhaust, and boost-cut controller like you can with the 2JZ, with the right mods you can also make MkIV BPU power levels out of a stock 7M-GTE reliably even on a high mileage daily driver MkIII with no big problems most of the time as long as you do decent maintenance and monitoring.
