1 - 3 of 3 Posts
Senior Member
Hey all..just took off my 65k struts and springs and replaced them with some low mileage ones off a 97 supra. I feel that I have them installed correctly however whenever I go over a bump or dip in the road I hear a bumping sound coming from the front wheel well's (mostly the passenger side). As you get up to highway speed and hit seems in the road the noise is gone so I assume its only makes the noise when the struts/springs are really bending.
What should I do?? Suggestions?
Jeff M
First thing you should check is that the new 97 assemblies had bumpstops installed with them. If not, you can purchase a set from toyota and re-assemble the 97 assemblies using bump stops.
This should be the first thing you check.
Pete
1 - 3 of 3 Posts
