1 - 11 of 11 Posts
1987 Toyota Supra Mk3 7M-GE
Is there anything other than the normal stuff (oil filter, oil, etc.) that is worth changing before I try and start it?
261745
After you change the oil, I would pull the ignition fuse and let it prime with oil for maybe 30 seconds or so. I would drain as much old fuel as possible, add a couple gallons of fresh gas, then disconnect the line to the fuel rail and let it pump out the old fuel into a bucket until it looks clear with the new. Lastly, replace that fuel filter. Otherwise, send it.
Just a guy who loves cars
94' Turbo, Targa, 6 spd, Ren Red.
Spark plugs, roll the engine by hand verify it is not seized. I would take a look in the cylinders and intake tract to ensure they are full of water since the car looks like it was submerged. Also, ensure there are no critters who have made their home over the years. Pull air filter as well.
  • Like
Reactions: jdm-rhd
I think "looks like it was submerged" is typical for a lot of older cars in the UK.
...pop the hood!
congrats...
and welcome to the money pit
I was gonna say, its dry mostly apart from the quick wash I gave it, just looks like this because of all the crappy stuff like the amount of salt on the roads here.
was going to replace the timing belt and pulley aswell, is it worth it?
To see if it will run, no I don't think so. If it does run then do it all. Oil and water pumps, belts, definitely tensioners.
Discussion Starter · #10 ·
ok thanks, will do. My main worry is the body of the car honestly, spoken to a few guys on fb they think it'll cost £5000 to get it sorted out.
Well, good luck. I hope you can get it all sorted.
1 - 11 of 11 Posts
