281 - 300 of 308 Posts
handy with the steel
Sweet. Thanks for the confirmation!
I'm back!
Hey guys, my IS300 has the Subara BRZ rear end from the but the gearing totally sucks! It has 4.11 gears that run out way too soon. Can anyone assist me on figuring out what can fit in place of this and what can get me down to the mid 3s on gearing? I have looked for a ring and pinion for this rear and but NO ONE makes 3.xx for it, everyone wants more than 4.
Boost Junkie
Id reach out to PHR and see what they recommend.
STeve
Super Moderator
Discussion Starter · #284 ·
It's the same R&P as used in the MK3 Supra. So any MK3 3.73 or 3.91 R&P will drop in to the IS300 diff housing when properly adjusted. A 3.58:1 R&P set is available as well, but only as a used part.
Weir Performance is another good place to call - they deal with a lot of MK3 and other Toyota rear end parts.
Dr. Jeff Lange
41201-80125 is a 3.58:1 gear set that should still be available from Toyota. It was used on European models until 2010, so you may need to bring it in from Toyota Europe or Japan.
41201-80050 is a 3.73:1 gear set
41201-80052 is a 3.91:1 gear set
Jeff
Super Moderator
Discussion Starter · #287 ·
Exactly what I need for my gs6-53dz convesion. Do you have any more info about this diff? The 3.133 diff is nearly impossible to find where I live and the 3.266 is too short for this setup.
Thanks to information shared by Jeff Lange, I know that the FD21A nomenclature matches the newer designations of what we call the 200mm 'small' diff in reference to MK4 compatibility. The illustration seems to show it as being very similar if not identical to the later Lexus 200mm carriers, such as those found in the SC430.
Compatibility with a MK4 chassis is unconfirmed. Potential issues include incompatible axle stubs and an incompatible drive shaft flange. But adding a 2.917 would be exciting for the auto guys.
I have a 98 supra that was originally a N/A car with an auto transmission but I went ahead and did the TT JDM non-vvti swap with the 5 speed transmission. I want to upgrade to 6 speed V160. Do I have to change my differential? If so can anyone tell me if this looks correct for a 6 speed TT differential? I am making a deal with someone but want to make sure its what's being advertised. Thanks in advance.
Super Moderator
Discussion Starter · #289 ·
Yes you need to change your differential to match a V160. I don't mean to sound salty but that has been exhaustively covered on virtually every V160 conversion thread/faq/etc for the past 15+ years, and if you haven't established those basics I would really encourage you to dig deeper and do more research because a V160 conversion is very expensive these days, and I hate seeing fellow enthusiasts under estimate their budget and end up with a parked, half-finished project or worse, have to part things out at a loss because it ended up being too expensive to complete.
The picture is a big flange 220mm 'big diff' from a Supra, and depending on the market it will be a 3.133:1, 3.266:1 or a 3.538:1. The picture isn't quite good enough to say for certain but it looks to have the 1-pot 'NA' rear brakes which would firmly establish that rear end as the 3.266:1 from a 93 to may 96 JDM Supra RZ TT 6-spd. As such, it would be perfect for a V160 conversion and could use all the OEM TT 6-spd support parts to complete the install (drive shaft, etc). Either way it is overwhelmingly likely that it's a 3.266:1 JDM RZ subframe just because it is incredibly unusual to see a US spec rear subframe sold in that fashion, and the 3.538:1 was a Euro/Mid East market option only and profoundly rare compared to the already uncommon US spec cars.
Be mindful also about the OBD-II complications of the swap, being a '98. It will vary by county in California as I understand it but it is extremely problematic to get a JDM 2JZ-GTE swapped fully over to an full Cali-legal OBD-II compliant configuration that'll pass BAR standards.
Thank you for your expertise bro.
DRiFTT
Exploded my diff yesterday at the track. 3.266, TT 6speed diff.....not sure how, but car makes only 506whp and launched at 4000 rpm....I AM seeing a blueish mark on one of the broke pieces which is leading me to believe the last owner broke something and possibly tried to weld it, and it gave up and exploded. Red silicone on back casing also, doesnt look original.
DRiFTT
Just got an open Aristo diff from a TT Auto and welded it up....When installed, i realized the flange to driveshaft and rubber is 1 inch shorter......
Any advice? Could the flange be swapped and make up that 1 inch or is it just the housing itself is shorter and i would need an adapter made?
Game Over
Does anyone know if the back half of a GS/SC400 Big diff driveshaft, work with a SC300's W58 front half?
I just picked up a SC300 5M/T as a new daily, and I'm thinking of swapping out the 4.083:1 small diff, for a 3:266:1 big diff
Super Moderator
Discussion Starter · #294 ·
Hey man - been awhile!
SC400 driveshafts with a big-diff flange are hard to find but should work. Only came in 98-00 model year SC400's with the VVTi 1UZ.
Best bet is to find a GS rear half and have a driveshaft place cut/weld/balance the big flange onto your existing 5MT SC300 rear section, or rebuild the 3.266:1 diff with a new pinion seal and crush sleeve and all that jazz and simply install the small flange from your 4.082:1.
  • Like
Reactions: Boost Wang
Game Over
Hey Jeff! Good to see you still on the forum even after the recent changes lol.
It sounds like those two driveshafts simply won't pair up unless there was some welding involved after all.
I ran the two final drive ratios on Tremec's gear ratio calculator with the W58 and it seems the 3:266:1 would drop the RPM each gear by approximately 500 at a given speed. Part of me is telling me it sounds great for a freeway cruiser, and another part of me feels like it might be a little too much for taking off from dead stops lol.
Then again, I get why people usually don't go through with this due to the hassle of the swap. Maybe I'm just lazy. A small diff TT auto Supra sounds great, but nowadays they are $$.
A 3.916:1 small diff SC400 sounds like another cheap option that drops right in, but the change sounds like it might be negligible. But man, the 4.082:1 feels really short behind the W58. You can literally buck the clutch from a stop without throttle input, and it won't stall the car lol.
Super Moderator
Discussion Starter · #296 ·
Yeah, everything about this forum update is trash - absolutely 100% cancer, but it's what we've got now. I'd buy lottery tickets just to try to buy this place back and restore it to what it was. Lol.
Honestly, I only saw your post because I'm subscribed to email updates for this thread, figured I'd drop in.
So anyway, a Tremec changes the ideal options a LOT - being a double overdrive (meaning 4th is 1:1, unlike the single overdrive Getrag which 5th is 1:1) means that more rear gear is just fine, unlike the Getrag. A Tremec with a 3.266:1 behind it will most likely just be way too tall unless you're building a salt flats car or something crazy.
Personally, in that situation, I'd find a 3.76 from a late model SC430 and drop an LSD in it. That'll give you a good split between the extremes. If it were my car, I think you're bang on with the 3.916 choice, just rebuild the whole thing with a fresh pinion seal, crush sleeve, etc, and use the flange of choice for the DS you fab for it. Also a perfect time to drop in a Giken Super lock or Kaaz 2 way, as well!
Edited.
what front and rear combo driveshaft can I use for a r154 and a 3.266 pumpkin from a SC430 on a 94 NA JDM SZR?
Sorry if this question been asked before. I appreciate your reply and your help! cheers, brother!
Rishi
Super Moderator
Discussion Starter · #299 ·
Rishi, sorry for the delay brother. Been busier than all hell the past couple weeks.
Thing is that the R154 never came in a JZA80 chassis so a custom R154 slip yoke->stock center carrier section is needed. A TT auto rear section is perfect for the SC430/GS400/LS430 diffs in a MK4 on the stock flanges and such, just need the guibo/rubber donut thing as well of course. So I'd get an R154 slip yoke and a stock TT auto complete drive shaft. Then with the R154 mocked up in the tunnel, install that TT auto driveshaft and get a total overall length measurement you'll need from the R154 slip yoke to the carrier bearing, take a bunch of pictures, and then bring the yoke and TT auto front driveshaft section to a drive shaft shop and have them make a custom hybrid using the R154 yoke.
That stock 3.266 is going to be pretty tall for an R154 but it'll be great on the top end, and the stock SC430 diff as you know is an open diff, so once you go NA-T you'll need an LSD of some kind. If you're eventually going CD009 or V160 I'd stick with the 3.26, if you're going to stay R154 I'd go with a 3.769 out of a later 06-10 SC430 and if you were going Tremec 6spd I'd leave your NA 4.082 or 4.272's in there. Since the NA diffs have the smaller flange, you'll do the same process with an R154 yoke but using your existing NA driveshaft instead of buying a TT auto one. I hope that makes sense and helps!
No worries, my man. I understand. Better busy than idle.
Thanks for the information, I appreciate it so much.
Now I know what direction I'm going to go with. I have the 2007 3.769 diff right now which is open and a 3.266 on order. (Buying parts is a friggin addiction- my wife hates it!!!)
I have a torsen LSD in my 4.08 that's on my car right now.
So I'll use the R154 for now with the 3.769 with the torsen till that blows up down the road, and then bring the 4.08 back when I save up enough money to get a Grannas Tremec and a proper LSD (whicheber comes first)
And here, I had the assumption that the 3.2 will work well with the t56 as well, that's why I was even considering that, Good thing you cleared that up for me. Thanks, man. You are a wealth of knowledge and we all appreciate that you share it with us.
Wishing you the very best, brother.
Cheers!
Rishi
Sent from my SM-N960U using Tapatalk
  • Like
Reactions: FasTTurbo
