I've been trying to properly setup my new set of Tein Flex coilovers for my car.
According to Tein, reference values are as follows:
Is the preload setting (dimension A) extremely important? I was reading somewhere that since the springs are linear, it doesn't really matter if there is preload at all since compression anywhere on the spring will be the same (hence "linear spring rate")
I'm asking because the 10" dimension A setting (I've only worked on the rear of the car so far) creates approximately an inch of preload on the spring which makes adjusting height (dimension B) impossible. To change height, I'm forced to completely get rid of the preload (and we all know how slow turn things get when there is a ton of pressure on a component), adjust height to what I want, and reset the preload on A to get the suspension with Tein's recommend spec (and in theory this will set dimensions C and dimensions D accordingly)
This normally wouldn't bother me but I am guesstimating the height of my car right now which means I need to make several rounds adjusting dimension B to get that exact height I'm looking for. Unloading, reloading dimension A, combined with jacking up and dropping the car = easy one day's of work if so. Also, I am worried that even though the preload does not affect spring rate, the difference on the load in shock will change the driving characteristics of the vehicle too.
It would be great if someone with expertise in suspension and chime and and let me know the physics behind this and whether it really matters or not.
Thank you in advance,
Calvin
Calvin
