Kenwood eXcelon KAC-X201T
5596 Views 1 Reply 1 Participant Last post by  speed101
this amp is used one month but in mint condition I am selling it for $229 shipped this amp is very heavy and high powered I got this ad off of the crutchfeild web site here is what I paid not including shipping let me know I only have one sold car do not need
KAC-X201T
Item #113KACX201
In Stock - Yes Our Price - $319.95
Play loud, run cool! The more energy made available to your speakers, the better they will sound. And the Kenwood eXcelon KAC-X201T amp converts energy with big-time efficiency, so it draws less current from your car's electrical system than most amps.
The PowerSlide door helps eliminate heat buildup by pulling in cool air through side vents and exhausting hot air through the top-mounted fan. Kenwood's new Bass Management System lets you select a bass frequency and adjust its level of enhancement to match your car's acoustic environment. And you can control both features from a compatible Kenwood eXcelon receiver.
Key Features:
stereo, bridged mono, or Tri-Way output
75 watts RMS x 2 at 4 ohms
300 watts x 1 in bridged mode
150 watts x 2 at 2 ohms
requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
MOSFET power supplies
2-ohm stable in stereo
PowerSlide door to access cooling fan and recessed controls
Sigma Drive for high damping factor, which means tight, clean bass
50-200 Hz high-pass crossover, 12 dB/octave
50-200 Hz low-pass crossover, 18 dB/octave
infrasonic filter, off/25 Hz, 18 dB/octave
large secondary capacitors for more energy storage
preamp outputs
10-5/8"W x 2-1/2"H x 10-11/16"D
See less See more
1 - 2 of 2 Posts
so do you guys think Im asking too much how come no reply???? make an offer
1 - 2 of 2 Posts
