Us And Them
sorry if this is the wrong place to post.
Now i've checked all the fuses and none are burntout.
Well i've installed my alarm and it works great but i messed up one thing and for the life of me i can't figure this one out.
In order to connect the door trigger you have to tap into the dome light wire for the signal.
I don't know how it is stock (should have written it down) but right now when i probe the wire it reads + and when i give it - then the light will turn on no problem, but when i open the door it won't turn on.
Any help is appreciated
I've looked on the tsrm but i don't think i read it right.
(i can explain again if this dosen't make sence)
Us And Them
well you can go under the dash on the steering harness or you could save some time and use the red/yellow strip on the little green light in the pedal area, just tap into it.
And yes the switch is set for door.
I'm puzzled and that sucks because i hate having to turn on the light manually then having to back in when i find out that i forgot to turn it off:(
