1 - 4 of 4 Posts
ok my car has a knock sensor code and it smokes a very rich fume from the exhaust. just wondering if the reason for this would be a bad knock sensor. plus my engine light does not come on the only way i know that there is a knock sensor code is when i diagnose it. i tried pulling the efi fse and resetting the ecu. but when i try back it has the same code. any suggestions guys.
Thanks.
With the code on the car will be running in limp mode causeing it to run rich. You will prolly need to do a rewire on the knock sensors or replace the sensors themselves. Before you do all this check to see if the sensors are loose too.
where are the knock sensors located plus when you say rewire what do you mean
sorry i'm kinda new to this.
Thanks.
The knock sensors are located on the drivers side of the block in the middle. There is a write up on it somewhere on the sogi website.
1 - 4 of 4 Posts
