1 - 8 of 8 Posts
i used black krylon acrylic paint ( suggested for coloring plastics) on my door panels and at first it was ok, but now that summer came, and i live in sothern cali, its begining to get sticky and lint is begining to stick on the painted panels. i put several coats of krylon black and several coats of clear coat krylon. Is there something i can do to put over the krylon that will stay black and stay on without sticking???
SUPRAF0RUMS TROLL
yea... a matte clear coat... or you could get paint remover and remove the paint and dye it like you are supposed to when dealing with interior pieces
2JZ Mk2
Clear coat????? Did you use paint or dye when you did it? Dye like the SEM trim paint doesn't have a clear coat.
Piyaud-Baka
should of gone dupicolor, i suggest taking the time and redoing it, its not gonna get any better the way it is now
I used Duplicolor and Krylon....one to dye vinyl, the other to paint the plastics. No problems so far. I think I still owe some ppl the info on what I did, but I really just followed the info here and on SM.
Acceleration
Sounds like most people don't understand the problem. He used plastic paint... on vinyl. Shouldn't expect anything BUT bad results when you use the wrong paint.
Satan I did the same thing, vinyl paint for vinyl, plastic for plastic. It's been 1 year and it's holding up great. Cleaning/prep and light coats is very important.
Do it right or do it again ;)
1 - 8 of 8 Posts
