1 - 7 of 7 Posts
I got new tires with alignment done 4000 miles ago and I have
inner side rubbing problem which is bad camber setting problem.
Here's what I got before,
Front:
Camber - 1.0 degrees
Caster + 5.0 degrees
Toe 0.00 mm
Today I got re-alignment done with this numbers,
Camber - 1.8 degrees
Caster + 3.2 degrees
Toe 0.00 mm
The alignment guy says I have problem with Camber setting
based on specification from TOYOTA "Minimum: - 1.3 ~0.3"
and I got - 1.8 degrees which half is still need to be adjusted.
and I have to have aftermarket Camber Kit .... to fix this problem.
I got Eibach Pro-kit Spring.
Do I really need Camber kit..??
Thank you for all your inputs.
If he told you that you need an aftermarket camber kit, then go somewhere else. He doesn't know what the hell he is doing. I just had my car aligned to Lance's specs and they are dead on. You just have to do more adjusting to get that much caster out of it while keeping the camber. My car has Eibach's and Koni's. Being lowered doesn't mean it can't be done.
EchoDeDupra
^^^^^^^^ what he said
mkiv's come with factory camber adjuster kits.... that mechanic didn't know what he was talking about
Suprasarecool said:
does the lance alighnment need to be modified for larger wheels and tires?
I'm not sure about that but,
I got F: 235-45-17
R: 275-40-17
so I don't need camber kit.....
:iwdumbass I feel DUMB... and he's DUMB too....
Thanks for all your inputs !!!
Shawn Davis
You need to run away from this guy as quickly as possible. The camber is adjustable on the MKIV so regardless of tire size you do not need an aftermarket kit.
I don't even need to talk to this guy and he called my car as
CELICA..... :confused:
1 - 7 of 7 Posts
