1 - 2 of 2 Posts
S
besides vavle cover gaskets,main seal,where are other places you can leak oil on the 7mgte??? i'm buying all gaskets and seals today and want to buy everything that have the potential to leak,mainly the stuff up top thanks.
If you are going for the main seal buy an oil pump seal also. The pump is driven off the timing belt. If you haven't replaced the timing belt in awhile you should do it now. I did this stuff last weekend. If you are this far dow like me, I also replaced all of my oil/power steering soft lines, belts and upper/lower radiator hoses.
1 - 2 of 2 Posts
