We had my car on the dyno and couldn't get past 19.5 psi without the wastegate leaking. I have a BL 67mm 4" into a BL 4" down and midpipe going into a 4" to 3.5" adapter to a apexi spec gt. My tuner is suggesting the flow restriction with the 4 - 3.5 adapter is causing excessive pressure resulting in the wastegate not holding.
I agree, and was considering cutting the adapter out to make a smooth transition from the 4" midpipe to the apexi 3.75" pipe.
I am finding the apexi a little too loud under boost so I am considering a super drager. Does anyone know if the super drager will flow enough to allow 24 psi? I assume any 4" exhaust will be even louder than my apexi spec gt?
Any other exhaust suggestions?
