1 - 3 of 3 Posts
I compared the Lexus pan with the stock TT pan - holds exactly one quart more! Holds 5 qts VS 4 for the stocker. Nowhere close to the 2-3 extra qts guys were claiming, and that I was hoping for! :rolleyes:
With an 8 qt capacity to start, one additional quart obviously is only 12% more. Additional fluid always helps, but I would not run out and buy one unless you were changing the fluid anyway.
Al
In theory, if you are only getting 1.8 qts out of the pan - without first pumping it out the front lines - the transmission would not get any oil. :scratch: That pan has to be full of oil for the pickup to circulate any oil, and gravity should make that happen!
I pumped mine out the front first - big mistake - a friggin mess when it started sputtering!
Al
1 - 3 of 3 Posts
