Hi guys,
Can you give me a quote on the parts I need for my LS400, and UK shipping?
It's a 1998 car with VVTi, VIN number is 3UF2000116433
I need the cambelt, all the tensioners/pulleys which need changing, the water pump and a gasket. Shipping to mainland UK (London). Let me know if you need any more info.
Thanks!
Hi guys,
Thanks!
Your VIN is nat a valid USDM #. Is it a Europe spec? I can quote you US #'s if you want, but won't be able to verify them for your application.
Hi,
Yes, it is a UK supplied car. If you could quote me the part numbers you have, I will see if I can check them with the owners club to make sure they are compatible. Could you also quote for a set of sparkplugs?
Adam
Hi guys,
Thanks!
USDM part #'s for 1998 LS400
13568-09070 timing belt $39.32
13503-0F010 idle pulley $63.69
13505-0F010 tension pulley $63.45
13540-50030 tensioner $40.16
16100-09201 water pump $102.64
16271-0F010 wp gasket $4.20
estimated shipping via US postal service $55
quote # Q655357
You were on the phone with my co worker Viet and the phone connection dropped before we got all of your information. Please call back when you can.
