1 - 8 of 8 Posts
Ok I know that you don't want a lighted underdrive pully because it throws the balance of the crank off, leading to short bearing life. but if you get a lightened flywheel wouldn't you have the same problem also?
I'm debating on getting the fidenza flywheel but I heard that some of those flywheels are off balance. If that was the case, wouldn't it throw off the harmonic balance on the crank?
If you're so worried about that, then take it to a machine shop that balances flywheels, and have them take care of it. :bigthumb:
Captain Hammer
If you mix fidonza and ACT.. make 100% your step height is 17thouh, or else you'll have disengagment issues, I had to pull a tranny 3 times because of it
1 - 8 of 8 Posts
