·if anyone can help me with some dimensions or a link to them it'd be great.
length of 2jz-gte motor(firewall to radiator)
width of 2jz-gte motor(intake manifold to turbos)
height of 2jz-gte motor(oil pan bottom to valve cover top)
wheelbase of mkiv
rear track width of mkiv(hub to hub if possible)
they can be estimates using a tape measure but if you know the factory specs that be even better.
also, is the mkiv rear suspension a solid one-piece axle case with internal axles and diferential, or is it an independant setup with the diff mounted in a separate case between the rear suspension arms?
-adam
wheelbase of mkiv
-adam
