1 - 20 of 21 Posts
here is my engine setup
ge pistons 20 over
crower rods
ferra valvetrain
arp head studs
tell me i am going to take my engine to the machine shop am i forgetting to get here
i am thinking of getting some cams any advice and where to get them.
Discussion Starter · #2 ·
look to be spending 5k+
im doin the same exact build up now... dont forget to get arp's for the rods and mains..
Over 10 years on SF....
5k+, damn might as well get a 2jz :).
I'm gonna be rebuilding but I don't expect to pay more then 3k ( Although i get free machineing ).
Woooossshhh said:
i would take a fully built 7m over a used 2jz anyday
Whatever floats your boat. I probably would stick with a fully built 7m too since I have an 87 which makes JZ's harder.
Someday though ;).
thanks men i will order thoose next
i am going for speed and hp
i am looking for an 11 sec
anyone ever heard of paisley automotive he has got a 8 sec sup 4th gen. though
his shop will be doing the machine work and tuning
hope i am not missing anything:cool:
chevyeater-on-sf said:
I kinda doubt Paisley is going to be doing the machine work in house.
u idiot do not jump to conclusion a friend of mine know his father personally
i never said it was going to be (in house)
nothing is for free in ny :finger:
please dont try to be smart
wastegate hose is pulled
Simmer down there killer. Just trying to give you a heads up if you didn't know. I'll be sure not to do that ever again.
Discussion Starter · #13 ·
did you change your cam,or you use some na cams or did you buy aftermarket for your set up
VIVA LA M.A.S.H. Midwest
JE pistons.
TRD rods.
Cut and shaved crank.
ARP rod bolts.
ARP mains.
ARP head bolts.
2mm MHG
Ferrea +1mm over valves
Ferrea chrome molly springs
Ferrea Titanium Retainers
NA cams
Unorthodox Cam gears (I think thats what they are)
Fully ported pollished head
3 angle valve jobbie
Modified new stock oil pump.... 35-40psi at 1200rpm
Prolly some other stuff to, but I can't remember.
As for going into the 11's?????
Uh search button my friend, search button.
Lots of money, and plenty of boost.
On the edge of adhesion..
YOU ARE MAKING THE BIGGEST MISTAKE OF YOUR LIFE IF YOU HAVING PAISLEY DO THE WORK. Those assholes took 10 months to build up my motor and when I got it back I had to do it all over again. They have no idea what the fuck they are doing and the cost me a lot of heartache and wasted money. I have so many horror stories from that place it is unbelievable. I just got finished putting a new set of bearing in my car, they didn't even know enough to put the correct bearings in my car. PAILSEY AUTOMOTIVE SUCKS!!!!!
Discussion Starter · #18 ·
wow u are the first person said bad things paisley but i was also thinking of how much they charge its f--k--g way up there, thanks for the advice though good to know
Cams?
Just go with NA cams, as they seem to do a great job on the dyno and they are cheap! (I bought mine from NAPA for like $232 a pair!!!)
As for aftermarket cams, talk to Web Cams, or hope and pray you find a set of HKS on ebay for under $500.
1 - 20 of 21 Posts
