Its very hard to search reasons why people have problems reving past a certain rpm. You cant search rev or rpm on here because of the length of the words. I know theres alot of reasons but I want to be able to check over everything. If you had a problem and fixed it, tell what the problem was and the solution. Just keep it short and sweet. Thanks
Reasons I know.....
Map sensor
Ecu
tps
timing
fuel pressure
anybody have any weird ones???
My rpm will go to 4000 rpm and bounce back and forth. I try and drive it and no power. Struggles to move and hardly any response from the gas pedal. It revs to 4000 rpm in neutral normaly but once I drive it, it cant find any power. Any ideas? knock sensors? Timing?
New.... ignitor, coil packs, caps in blitz ecu,
tried 2 different map sensors
Reasons I know.....
Map sensor
Ecu
tps
timing
fuel pressure
