So Sport Compact Car just finished the write up on the new suspension on my miata. Just thought I would share the results as I am pretty pumped about them.
76.6mi/hr through the slalom (the new rear wing added 2.1mi/hr!!!)
1.09g on the skid pad
And this wasn't on optimal tires. My Avon Tech R tires had been beaten up on 3 track days before we did the tests. They had dropped off significantly on track before we tested them.
the setup is:
15x7.5" SSR Comps with 225/45/15 Avons
KW 2 way adjustable coilovers with 60Nm springs
Garage Vary front lip
APR GTC-200 rear wing
It was then on Streets of Willow. I ran a couple upper 1:30's running counter clockwise. (Terry or others - what do you run in this config in your supra?) I better driver could probably pull another 2nd or so out of that...
When I get some pics and a better write up on my website I'll let you know. The write up will be in the August SCC.
Matt
the setup is:
Matt
