Yep, and catching detonation before it gets out of control.Planning on tuning individual cylinder fuel trims, I'm guessing?
Funny enough, I wanna try and run a pressure sensor in each cylinder somehow so I could technically do a running compression test per cylinder and get more accurate data.Yep, and catching detonation before it gets out of control.
Right, I know you could put tiny hard lines and coil them to cool off exhaust heat for back pressure sensors just would be an engine bay full of spaghetti lines everywhere 🤣.I think back pressure sensors are a far more realistic concept in this case than cylinder pressure, IF you could get sensors that tolerate the heat levels to be put into each runner.
That said, I have always wanted to know just how high dynamic compression ends up being with boost. I know that boost signal is taken from intake manifold pressure, but I have a scientist's mind...
I'm trying to build at F1 level 🤣Yeah, to say the least, that's something best left to the engineers developing at the OEM / F1 level...
I'd caution against such enthusiasm, it's a quick way to run out of budget...I'm trying to build at F1 level 🤣
That's why I want to go the BMW DCT and get my speed set through gearing and not power. My supra is being built for autocross/ time attack/ endurance blah blah blah lol. But yes even though the DCT are heavy bastards I think its worth the weight penalty and reliability. And since I'm planning on going 1.5way LSD rear end my biggest thing is constant abuse reliability.DCT costs just as much as sequential, plus you get the added fun of having to figure out how to tune a transmission as well as your engine. Truthfully, on paper, they have a LOT of potential. In reality, at least for now, they are a long way to go before they are what I'd call ready for the mainstream. Give it another 5 or 10 years of development and DCT's will probably be really nicely sorted, known qualities.
The biggest advantage the BMW DCT has over the HGT (and any of the other sequentials I have looked into) is the gearing spread. Having that seventh gear really allows you to have a fantastic first gear, as well as an actual highway gear in seventh. Would be perfect for autocross, road course, highway use... the gearing is just fantastic. Sequentials are more geared toward road course use, so you often have a reeeeeeeally long first gear, and a super aggressive sixth gear. Not great for autocross or highway use as a result.
However... a sequential is nice and light. If I recall correctly the HGT six speed is only like 80, 85 lbs... and it's a LOT simpler to integrate. If I had the money I'd be all over one myself.
