1 - 3 of 3 Posts
What are your guys methods of loading driveline off the line with a 6sp v160. I don't want to brake anything while launch. I have my 2step set at 5000rpm and about 8psi of boost. Is that to high??
Line lock on the rear wheels, with the same switch that turns off the 2-step turns off the line lock. This obviously would only help if they turn off about half way into the clutch engagement.
We had it set up like this on our AWD Talons years ago. It was controlled by the cruise control switch on the clutch pedal.
Al
1 - 3 of 3 Posts
