1 - 20 of 53 Posts
As far as I could tell no one could find what we needed to work in the MKIV's.
I want to most of my dash in blue led to match my stereo, but have no idea what is needed. I have a little electrical knowledge, but dont want to screw with replacing resistors.
michaelvanle knows how. too bad he doesn't do it anymore it was nice
he did mine
he did my cluster, ac unit, boost gauge,clock,odo, and turn signals
Useless Member
It's ok...you'll learn. I only recently got what FTW meant. Kinda stupid though, I'd never use it...
It really is too bad that michaelvanle doesn't do that anymore. Your dash is lookin' good! I would try, but I don't have the time, nor the know-how to attempt it, nor the time to learn! Vicious cycle!
magicsupra, yours has resistors, right?? Which ones are just plug and play?
Newbie
Your stupidity ftmfw, jk :lol:
The cluster (speedo, fuel, tach, temp) is plug/play. Everything else is custom soldering (using resistors to aid).
Hardtop >
I did my gauge cluster in red. The gauge cluster is lit up by three 194 sized led's, and one 74 sized led. The red 194 led's i used are 5 led refractor bulbs. There is one led in the middle that points forward, then there are 4 led's that are on the outside that point around the housing of the bulb. Then i used one red 74 led.
Here is the link to the red 194 led's i bought -> that auction is for the perfect amount of bulbs needed to do the red led swap
Here is the link to the red 74 led i bought ->The 74 led's come in a pair. You only need one of them though.
I dont have a pic of how they look, but they are pretty bright, and match my red Defi BF boost gauge almost prefect. You wont be dissapointed with these led's!
1,150+ rwhp club
These lights are plug and play? I really need to take my cluster apart and get a sample bulb.
Hardtop >
Yep, those led bulbs are plug and play. You remove your gauge cluster from your car, take out the existing oem bulbs, and replace them with the new led bulbs. Then you hook your guage cluster back up and enjoy the new look!
1 - 20 of 53 Posts
