1 - 9 of 9 Posts
ive searched and found alittle info, but need more
im looking to replace my wheel studs with longer ones and add 10mm spacers to all 4 wheels. I need to know how difficult this is, and how involved the install prcoess is?
Also, ive only found HR spacer/stud kits for our cars, is there any one else that sells/makes them?
any and all help is appreciated
-mike
how hard is the install process? do i have to take off the brake caliper? does that require any specail tools?
Newbie
I changed mine a while back. It was about an hour per wheel. I think I removed the calipers too so I can have more room. Just use a hammer and pound the old one out. Then slightly pound the new one in so it kinda sits. Then use a spacer and a nut and screw it on. It's a way of "pressing" it on.
that makes sense. is taking off the caliper pretty easy? anything special i should know.
i know im asking alot of questions, i really appreciate the info..
nero...could you possibly PM me and let me know if you have those ARP wheel studs in stock? If not, ill just call. thanks
1 - 9 of 9 Posts
