1 - 14 of 14 Posts
· Toyota Hybrid Tech
ive used the seach button but all i find is tires that will fit moddified fender wells.im looking for a street slick and rims that will fit my 95 na-t unmodified fender well with stock suspension. i cant hook worth a shit in first or second. the best i got last night was a 14.08 at 117mph.
· adammackintosh.net
117mph. sounds like 500rwhp :)
same as mine did on street tires. hooked 3rd most of the time and ran a 13.3 @ 120mph, with 496rwhp. now ive stepped up to 600 wheel and its 100% retarded on street tires. havent hooked 3rd since august (road/tires too cold).
checkout those r888 though. i always here crazy stuff about them and i will probably get them next time i get non slicks.
i think i even heard that they hooked 700hp in 2nd gear
Discussion Starter · #6 · (Edited)
lol well to be exact it was 485rwhp. i lost traction in third goin down the track but i think that was from my shifting, wasnt the greatest.
ya i seen some good reviews on the r888. but im more looking for tire for the track to throw on and take off after. heard the drag radials give bad wheel hope though, and that the M/T et street slicks were a better choice for the track. gonna do a bit more research, wanna see whats gonna fit in the slick department.
also kind of nervous about putting on slicks cause i still have the weak w58
... heard the drag radials give bad wheel hope though, and that the M/T et street slicks were a better choice for the track...
many 6spd owners with track experience recommend avoiding drag radials at the track. instead, they recommend DR's for the street and ET streets/drags (slick vs non-slick, both bias ply) for the track (bias ply = more forgiving sidewal and less drive line shock/broken parts). but also remember, no mixing bias ply rears with radial fronts.
regarding the 'weak' w58, you may want to avoid the full slick ET drags; others with more experience can chime in on that.
craig
· Super Moderator
craig
I cannot overstate how correct this is. The W58 can survive decent HP so long as you do three things - Avoid launching it, avoid unsprung/undamped clutches, and avoid big wide sticky tires, especially drag radials.
Personally I would ditch the 19's completely and go to a 17 or 18in setup. 17's have a lot of advantages particularly in the affordable awesome tire department. R888's are fantastic tires but they have stiffer sidewalls geared more towards road racing, and that stiff sidewall means there's that much less flex in the whole driveline between clutch engagement and pavement. Flex in that whole system between your clutch and your contact patch is what will save your W58. For this reason as well, do not for any reason eliminate the rubber 'donut' between the driveshaft and the differential.
Ultimately I would consider a moderately sticky summer tire like a Yokohama S.drive, and I wouldn't go larger than 275 in the rear.
If drag racing is what you really want to do, swap to a V160 or go automatic. The R154 is stronger, yes, but it has it's weak points as well and it will be on borrowed time at ~700-750whp the same way your W58 is on borrowed time at ~450whp. If you are happy keeping it under ~600whp or so, the R154 should work great so long as you avoid combining those evils of harsh launches, unsprung clutches, and huge wide sticky tires.
thanks for the info guys.
so why is it a good idea to avoid a radial up front and a bias in the back?
im really just looking for something for the track to put on and take off after racing. i dont mind the 19s for just street driving.i plan on being above the 600hp mark in the future. i heard the R154 if modified can hold alot of power, like 750plus? i dont really like autos, drove one for years when i had a cutlass i had done out back in the day.
the wheel hope is brutal when i launch and shift in the second, i kept having to let off and getting back into it, was killing my times all night, plus the newb driving wasnt helping either. id really like to go with the E/T street slick to help get rid of some of it.
again thanks for the info guys
... id really like to go with the E/T street slick to help get rid of some of it...
ET Drag = slick
ET Street = bias ply, non-slick
ok read a bit of info about the radial up front and bias-ply rear, now i know why not to do that. probably gonna jsut save up some more to get a set of drag wheels and tires
CCW drag pack is approx $3k; used sets come up for sale here not in-frequently for around $2k (think there are a couple listed currently in fact).
craig
1 - 14 of 14 Posts
