You only need one!
I put an MTX Pro 400x5 under the passenger seat. Very close fit but everything clears.....only had to take off the return spring for the passenger seat.
Amp is 4x125 watts at 2ohm per channel or 4x50 at 4 ohm.
Sub amp inside is 200x1 4ohm and 300x1 2ohm.
There are 3 fully adjustable electronic x overs built in (front,rear,and sub)
Very clean, high quality, and one simple install!!!!!!!
I will post my pictures of this tonight!
The current model is the 405 I think.
Todd
try this link to read about it yourself
http://www.mtxaudio.com/caraudio/archive/pro400x5.cfm
Blue Thunder PRO400X5 Amplifier
You'll choose the five-channel amplifier when you want a killer audio system. And you just want one amplifier to do it all. Drive the front and rear speakers, along with a subwoofer (and you'll pick Blue Thunder when you want low noise, high reliability, and the look of a champion).
Dedicated Class D Subwoofer Channel
External Bass Control Port
Front Channels: 18 db/octave Butterworth defeatable and continuously variable crossover (40Hz - 175Hz). The front channel has a frequency multiplier so you can change the crossover frequency for different applications.
Fifth channel: Class D subwoofer channel, with an 18 dB/octave low-pass crossover (Butterworth, continuously variable, 40-175Hz). With a Class D channel you get a very efficient amplifier, meaning more of its power goes to driving your speakers.
Specifications
RMS Power measured at 12.5 Volts DC:Front & Rear:
25 watts x 2 into a 4 ohm load with less than 0.05% THD+N
50 watts x 2 into a 2 ohm load with less than 0.1% THD+N
100 watts bridged into a 4 ohm load with less than 0.1% THD+N
RMS Power measured at 12.5 Volts DC:Subwoofer
100 watts RMA into 4 Ohms with less than 0.3% Thd+N
200 watts RMS into 2 Ohms with less than 0.5% Thd+N
Dynamic Power* Front & Rear
65 watts x 2 into a 4 ohm load
125 watts x 2 into a 2 ohm load
250 watts bridged into a 4 ohm load
Dynamic Power* Subwoofer
150 watts x 1 into a 4 ohm load
300 watts x 1 into a 2 ohm load
Signal to Noise Ratio
> or = 100dB A-Weighted
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
(0-18dB) centered at 45Hz
Crossover (Front)
Variable 40Hz to 175Hz
12-18dB/Octave
HP Defeatable with 45X Frequency Multiplier
1.8k-7.9kHz
Crossover (Rear)
12-18dB/Octave
HP Defeatable
Crossover (Subwoofer)
18dB/Octave, LP
Dimensions
15" x 9" x 2" (38.1cm x 22.8cm x 5cm)
16-1/4 Wide Including IsoFeet (41.3cm)
