Well I'm researching a system. Basically I have one main question, I was told the lower the Hz the cleaner and better the bass. I was looking at ma audio comps like 2k watts 280oz. magnets but had 32Hz. While MA Audios cheaper lines were under 20Hz down to 17Hz on their cheapest 10in. sub.. Yet focals run 30Hz and JL Audio run 20Hz.. so can anyone please clear this up for me?
I don't know what I want as far as interior speakers. I just think I will go with whatever company makes my subwoofers and use their interior speakers. I would like to stick with a mono amp but any suggestion are welcome. If you had to make a dream system post the specs here, because I am looking for expereinces and suggestion.
Now besides that this it what I am looking at for subwoofers right now:
12 Inch Extreme Competition Subwoofer
2500 watts RMS power | 280 oz double stacked strontium magnets | Dual 3 Inch black aluminum voice coils | 2 Inch treated rolled foam surround | Double stacked strontium magnets | Vented magnet structure for better heat dissipation | Heavy duty partial-pressed Spruce pulp cone for more solid bass, higher SPL| Chrome post terminals for better connection during hard hitting bass| Chromed aluminum 20 spoke cast basket | Dual 2 ohm voice coil which maybe connected in parallel for a 1 Ohm load or series for a 4 Ohm load | Rubber sealant gasket
Focal Audiomobile 33K
33cm (13") subwoofer for bass reflex enclosures
77mm (3") v.coil
180mm (7") magnet
Max. power handling: 800W
Nominal power handling: 400W
Sensitivity (2.8 V/1m) 94.5dB
Frequency response: 30Hz*-1Hz
JL Audio W7
Not really any specs, JL Audio.. nuf said
12.5LF - ProSeries Subwoofers
12.5LF - ProSeries Subwoofers Full Product Specifications
Nominal Size 12" (300mm)
Recommended Amplifier Power 50-1200 watts
Nominal Impedance 2-ohm/4-ohm
Mounting Cutout Diameter 11" (280mm)
Mounting Depth 5-5/8" (143mm)
Recommended Enclosure 1.0ft ³ (28 liters) volume sealed
Also looking at.
Alumapros Alchemy Series, Alpine Type R's, Image Dynamics, basically throwing every name I know. Looking for the best mix between SP & SQL...? I want to be heard 4 blocks away yet have the clarity to cruise.. Thanks as usual!
77mm (3") v.coil
180mm (7") magnet
JL Audio W7
Also looking at.
