1 - 14 of 14 Posts
Hi Curt- I have a 95 na auto going to usdm tt auto
These are some parts I need for sure:
1)tt resistor pack #28510-46020
2)TRD tt motor mounts (2=one set)
3)TRD oil cap #00602-12108-003
4)TRD radiator cap #00642-16401-003
5)97-98 fog light harness (I switched to 98 headlights and turns-but the connector for the fogs is different)
6)2 lexus V-8 supra upgrade oil filters
7)harness connector #10841 (to na fuse box)
8)JDM seat heater switch/button-A little project :)
These are some parts I think I need to make the swap work?-hoping you might know.
9)tt auto lower radiator hose (I already have tt radiator and upper hose)
10)tt cruise contol cable
11)tt throttle cable
12)tt heater hoses (3 I think)-not sure if I need these or just a good idea to change
13)tt igniter harness(I have an igniter and the tt engine harness,but is there a "sub harness" to the igniter?
That's about it for now-Thanks in advance and sorry about not finding /knowing all the parts #'s-Thanks-Donald :)
28510-46020 Resistor List 183.34 Cost 135.57
12360-ja800 Trd Mount List 128.80 Cost 113.16 Ea
00602-12108-003 Cap,oil Trd List 81.03 Cost 69.80
00642-16401-003 Cap Rad Trd List 37.56 Cost 32.35
81125-1b230 Cord, Fog Rh List 15.23 Cost 11.27
81165-1b230 Cord, Fog Lh List 15.23 Cost 11.27
90915-yzzd3 Filter, V8 Trk List 5.41 Cost 3.96
90980-10841 Electrical Connector List 8.17 Cost 6.26
84751-14030 Switch,seat Htr List 66.73 Cost 51.08
16572-46160 Hose, Rad Lwr List 13.66 Cost 10.10
83731-14040 Cable, Cc List 72.94 Cost 61.30
78180-1b090 Cable ,tb List 58.47 Cost 43.23
87209-14840 Hose Water List 24.81 Cost 18.34
87245-1b320 Hose, Water List 30.61 Cost 22.63
87245-1b330 Hose, Water List 37.81 Cost 27.96
90980-11152 Electrical Connector List 6.69 Cost 5.12
82998-12440 Terminal, List 5.20 Cost 3.85 X 4
Hi Curt-Got the order today-Thanks! Missing one thing-also ordering a couple more things :)
1)83731-14040 Cable, Cc List 72.94 Cost 61.30
2)pcv valve-#12204-46020[TT]
3)fuel filter-#23300-49195
4)I also need a tt power steering reservoir,any bolt for mounting said reservoir,the hose/line that connects it to the pump and the nipple that inserts into the pump that connects the hose/line to the reservoir.
Thanks again-Donald
Discussion Starter · #13 ·
Hello Curt-I ran into a problem today as I was trying to get my foglights in the 1998 style headlights to work on my 1995 supra-I ordered the parts: cord,head lamp #81165-1B230(LH) and #81125-1B230(RH) from you - But my cars harness ends in a triangular clip, and the parts I ordered end in a oval shape.Is there a different part I should have ordered and if so, can I send them back and exchange them?,they are unused. If not I will eat the cost and order the new parts-I just want them to work! Thanks as always-Donald
Cant you re-use the original ones from the 93-96 style headlamps? Do you still have them?? If so cut off the socket for the park lamp feed. Call me if you hav eany questions.
1 - 14 of 14 Posts
