- Idle great when the car is cold (~750rpm)
- After driving it for a while and the car warmed up, it idle @ ~950rpm. (I even changed the Coolant temperature sensor with TOYOTA OEM one and it's still doing it, though i feel the car idle & drive smoother.)
- Even with LEXUS AFM, I Hit fuel cut if i go WOT in low gears (1st, 2nd, sometimes 3rd) (boost set @ around 15psi)
- Car runs rich (tailpipe & bumper is black) & backfire in first gear.
- RPM dropped below 500 and sometimes stall the car if i push in the clutch too fast while the car is in high rpm.
- While cruising & staying at a steady speed, the car will buck/jerk everytime i push OR let go of the gas pedal. In lower gears, it buck/jerk as if it's trying to take your head off.
- I noticed that the car moves extremely slow (much slower than before) until 3000rpm (turbo kicks in). I know it's not normal because it never does this before. No it's not the clutch or BHG, i've checked.
- I got code 51 (yes, AC was off) & 34
- TPS is out of adjustment (because i took it off before)
- I can't change the timing to anything lower than 16 degrees.
- No Vaccum or Boost leak (i've checked) Vaccum is @ 20-21 in/hg @ idle. As for IC pipes, i've taken them out and checked and reinstall them with T-Bolts.
- Checked & tightened BOSCH Spec 110 recirculation valve
