1 - 2 of 2 Posts
Hey guys,
I had a boost leak on my 94 BPU for years and didnt notice it because I still got good boost. So I finally fixed it but forgot to turn my boost controller down. I hit 25 psi 2 or 3 pulls without realizing it. Since then it wont go much over 14 psi anymore.
I did a boost leak test for the sequential system and its completely tight. Did a leak test for the whole system (plugging in pressure at the intake manifold, blocking off the air filter) and I couldnt build up much pressure.
I couldnt find a boost leak anywhere, even with soap water, so I got a smoke generator and the smoke came out through the exhaust.
I then tried to spin the crank a bit (like some people say you should do if there is a leak during that test) and it never was air-tight. At some point, when spinning the crank slowly, it would build up more pressure than at other points, but it never was close to being tight.
I noticed my timing belt is 18 years/60k miles old (only driven in summer, though) and even before this, the car would jerk a bit when letting off the gas or in idle, or sometimes (rarely) would need a few more cranks to start and that has become worse since my boost problems. So my suspicion is that it jumped a teeth or two, and maybe one more during those pulls, and now the valves wont close properly anymore at any point of the crank position.
But I also fear that it could have blown something when I did those 25 psi pulls. Maybe a piston ring? A valve seal?
Thought about doing a cylinder leak down test, but that wont really tell me whats really going on, will it?
The car isnt smoking at all.
Any input is highly appreciated.
Check your plugs
Sounds like that would be my first place to diagnose.
Look at gap
If there is any build up on them
Or cracked porcelain
1 - 2 of 2 Posts
