THE Computer DR.
I installed a blitz turbo timer/boost gauge this weekend. Got in the car, everything worked fine, but when I took it for a test drive, I noticed I was only peaking at about 8.5psi boost. I have not installed a boost controller and my car is a completely stock TT with a Blitz intake, that's it. Anyone have any idea why it's boosting so low? Is it easy to pinch the vacuum hose thus reading a lower value? The car runs great and the boost "feels" really strong, so I'm just wondering if anyone can shed some light on this issue. thanks.
So, you have nothing to go on other than seat-of-the-pants feel? Yes, the hose can get kinked. Is yours kinked? How should we know- go check it. If the car "runs great" and "feels strong" then I guess you have your answer.
Boost4fun
I would link another (mechanical) boost gauge into the line with a T and look what this is saying. Just to be sure what´s going on under your hood.
BTW: WHere did you take the pressure source from?
THE Computer DR.
Ok, i think i figured it out. I had never really done a long pull in a higher gear. Did that and got a peak boost of .83hkpa (about 12 psi), I also removed a zip tie where it could have been pinched.
I guess the stock twins don't hit full boost in the lower gears??
I'm taking the reading from in between the "t" and the boost pressure sensor at the intake manifold.
I started to write that the max boost on the first turbo is around 8 psi but I figured from your post that "peaking" meant you did a WOT pull. I suggest that you look around on the forum for information about the sequential system.
