Hi i made it to the dyno to get some numbers today on my setup.
It was on a rototest
Supra Mkiv TT
Aem ems
Its72mm turbo 0.96ar.
3.5 downpipe and exhaust.
1680cc injectors
hks 272s
And so on.
I got 537rwhp at 22-23psi on e85 seems abit low i think.
Also i thougt it was bulding boost pretty slow, felt like something was holding it back.
I checked the turbo when i got home, it spins very easy cold if you spin it by hand. but when hot it turns kinda hard, is this normal?
Also it had started to rubb alot against the compressorhousing.
So i know the turbo is starting to go but i was wondering if it could cause the low number.
i was thinking if it flows less air then it should but still holding 22psi off boost can that be possible?
Ore could it effect the engine beacause its hard to get it to spin and hold boost.
Supra Mkiv TT
Aem ems
1680cc injectors
hks 272s
And so on.
