for the past month, I have been noticing my engine idles really low (~500rpm) and sometimes stalls when coming to a stop at a traffic light. engine starts back up fine. the stalling only happens when the engine is warm. a/c on or off doesn't matter. I had 2 different repair shops look at the car but they both could not find any problems with the car. shop #1 checked for error codes in the ECU but none found. shop #2 cleaned the throttle body but the stalling still occurs. here's my thoughts on other possible causes of the problem. my car currently has 66K miles. any suggestions? thanks.
1) sticky intake air control valve
2) bad spark plugs (last replaced at 30K miles)
3) water in the fuel tank
4) clogged engine fuel filter (last replaced at 30K miles)
5) clogged in tank fuel filter
6) bad front or rear O2 sensors
7) faulty fuel pump
7) faulty fuel pump
