I just changed out my waterpump, put a new timing belt and idler pulley. The car just has a cat-back exhaust and HKS intake. No other mods or ecu's. On a cold start the car idles at 3-400rpm. The timing was set using the marks on the cam gears and set to 0 on the crank pulley.
The car drives fine, boost is strong, but when I come to a stop (put the car in neutral) the car almost wants to shut off but doesn't...it just slowly jumps back to about 400rpm or so. I checked for loose vac lines, but i didn't touch anything else during the fix. The car ran perfect before this. Any suggestions?
Thanks in advance.
Thanks in advance.
