·i just fix my radiator leaking problem and now is working right. The prolem now is that my coolant is very very low. The bottle is almost empty. whoat should i do
Thanks guys. However, i still kinda confused. So i pour mixture from radiotor cap ( or overflow tank?) untill it top off overflow tank, then run car to operationing temp then top off overflow again. I know i am dumb but isnt distill water like drinking water? Is it the same water that i can get at those air/water machine from gas station?Complete system flush takes 10 quarts, or one bottle of coolant, and same size bottle of water. If you only wanna add coolant, pour 50/50 mixture into the radiator when the car is cold, and top off the coolant overflow tank.....run the car to operationg temp, then top off the coolant overflow tank.
This doesn't sound right to me. Distilled water would be the water that evaporated. The water left in the pot has more impurities that you don't want in you cooling system.MONSTER said:Make yur own distilled water, pour tap water into a pot, cook it until it boils, let it cool down and you got distilled water.
or you could fork over a whole 89cents for a gallon from the storeMONSTER said:Make yur own distilled water, pour tap water into a pot, cook it until it boils, let it cool down and you got distilled water.
Ed Zachary!!!!!! :bowrofl: :bowrofl:Adrian98 said:or you could fork over a whole 89cents for a gallon from the store
Of course, but we assume the guy still has not filled his radiator.riceage said:have you guys noticed that this thread is five years old?
