J
Jack Merchant
·Guest
I want to lower my car with some eibachs. I have a garage, a floor jack, four jackstands and basic tools. Will I be able to do this myself?
It's not hard.. just a little tedious trying to get the bolts / holes to line up. Here's a tech article from mkiv.com: http://www.mkiv.com/manual/manualtt/shock_replacement/index.htmlJack Merchant said:How about the actual install? Easy?
Is this because your tires had a sort of / \ slant to it because of the new springs?supra4life said:Just a word of advise.
Be sure to get your car the proper alignment once you install the new set of springs. I made this mistake just about four months ago and now my tires are gone! I have to get new set of tires because the inside wears are pretty bad for all four.
There are good articles to show you how you can do the right alignment in mkiv.com technical
