1 - 13 of 13 Posts
Does anyone know how different the LS7 is from the LS1 in regards to external sizing? I've seen a handful of z32 LS1 swaps and im just throwing around ideas for a couple years down the road here and wondering if there would be any problems fitting a LS7 in there.
NFA Pimp
There should be little to no difference in width wise in the 2 motors. Overall height might be a tad different due to the intake manifolds.
NFA Pimp
Just the sump is not there anymore. But it still mounts at the same points or close to it.
you need somewhere to mount the oil tank also. Katech put a LS7 in a 00 Camaro and it fit just fine. :)
Isn't the ls7 a dry sump though? Meaning the oil pan is a good bit shorter?
I'm not 100% positive, but the ls7 oil pan is not as small as you would think. It's smaller than the C6 pan because of the lack of sump, but not as non-existant as some might imagine.
Hmm, and I suppose for the price of a ls7, i could build a vg30dett or ls1 to be faster.....I don't know, just a thought.
It depends how radical you want to go. The LS7 intake and heads flow really really well; the stock LS7 intake flows better than a ported FAST, fyi. You would have to get some really good heads to make the LS1 a competitor, and then you would be spending quite a bit of money. Like I said, it depends on your goals. The LS7 is a lot of money upfront, but you get what you pay for. A great intake/ heads, and displacement? You're only a cam swap away from 540+. It's a hell of a deal; most people just don't need that (or a dry sump system for that matter).
I'd be looking to be in the range of 550-600whp on the street, regardless of what engine I'm using. My old TTZ was running at low 400 whp with a small turbo upgrade, and I'm sure I could maintain or improve that spool capability with headwork and manifolds with turbos capable of that 550-600 goal. That said, I didn't have a problem with lag at that level, very quick to build boost. So I'd probably be happy with the response regardless of what engine I chose, just a matter of if I want to get kicked in the chest or not when I go WOT. Guess I'll just have to add up all the costs for each setup and decide what kind of steps I want to do the project in in order to decide on what platform to use.
If you want 550-600rwhp NA, a 346 ls1 isn't going to cut it. Texas Speed sells a really cheap forged 346 though, so if you want to spray the car or something, you could look into that. A realistic 346 probably won't break 500rwhp.
I would say a 383 would be the minimum of what you would want to use. You could also do a cheap 408, but it would be an iron block. I don't know if weight is an issue to you. Tony Mamo from AFR has a pretty well-known Z06 with a solid-roller 383 making 540/480 at the wheels.
I Solve Problems
There are plenty of NA 346(non-forged) LS6's with over 500rwhp these days. Why not go that route?
A T-Rex going "Rawr!"
Or a 402 LS2 for half the price of a stock LS7 with much more nitrous potential.
I haven't seen any at that level. Do you have any specs? I would think you'd need a pretty radical setup to hit 500 to the wheels. There are a few Cartek C5's (among a few other cars) that have barely made over 500rwhp. It's possible, but neither cheap nor easy, and even then you'll have to consider the power band.
1 - 13 of 13 Posts
