1 - 13 of 13 Posts
Search
I just installed LSD last night... the pumpkin was marked LSD and the 'wheels' both turn the same way....
i did a burn out leaving work and my coworker said only one tire spun???? That's what I was trying to get away from...
what could be the problem here?
Search
a_zepeda9236 said:
consider the age of the thing...and the miles.
just because it locks with you turn it doesnt mean it locks with 3500lbs are on it.
I don't know much about LSDs man, are you saying that the thing is just no good anymore? does that happen to LSDs?
1.5JZ Turbo Supra
i have a similar problem, making left hand turns my driver side wheel spins only when making a right with some rain it will lock up drift and power slide, doing it to the left only lets 1 wheels turn =/
I heart 80's Toyota's
The stock LSD are a clutch pack style limited slip.... the frictional clutches, like the one for your transmission wear out over time. So if the LSD you swaped in has a bunch of miles, or was abused a lot.... well.... peg leggggg
EDIT:
here I pulled some stuff off cygnus
-Dustin
Formerly Nosechunks
well since this topic has been answered and this question is related....here we go...when u guys change the fluid in ur lsd diff, what do u refill it with? gear oil and an additive im assuming...what additive do u guys use?
NorCal Haters Club
We use the Ford Motorsport just because it is cheaper and works relly good. For a normal driver, non drag racer, mix 2oz additive per 1qt gear oil. Valvoline makes a good, reasonably priced synthetic or if you are concerned with heat run Redline.
NorCal Haters Club
catch2nd said:
I run the redline in mine.... myoilshop.com carries it pretty cheap... just make sure you order the stuff FOR LSD... its has a frictional modifyer (sp) already mixed in
Don't always trust the oils that have the lsd fluid mixed in. A llot of times the mixture isn't correct. We have experience in this situation.
Good to know.... FWIW, the redline has been working well.... I have about 8k on the fluid and the LSD still comes on strong
-Dustin
1 - 13 of 13 Posts
