1 - 8 of 8 Posts
Universal Ambassador ^*^
All My Lug Nuts Were Rusted And Stripped So I Replaced All Of Them And Got A New Set And Key. My Problem Is That 2 Lug Nuts Are Very Very Stripped And The Key Is Also Very Stripped. I Cant For The Life Of Me Get These Lug Nuts Out. Does Anyone Have Any Suggestions. Thankx Everyone And Any Help Would Be Greatly Appreciated.
helps you jump higher
desposible socket that is just barley too small to fit + hammer. Hammer it on and get them off, you will ruin the stocket and lug nut. Some epople have had luck with those "gator grip" type "fits all" sockets.
I have a stripped lug nut that can only be removed by a key lock. There is no room around the nut to put a socket over it. So I need to know how to get a keylock bolt in there that is bigger??????????????????????
you should change your avatar, I thought you were Steve Theodore.
How isn't there enough room around the outside of the lugnut to pound a socket on?
http://buy1.snapon.com/catalog/item.asp?item_ID=52120&group_ID=1652
http://www.amazon.com/gp/product/B0002T5IBA/103-5470220-5823834?v=glance&n=228013
http://www.sears.com/sr/javasr/product.do?pid=00947392000&vertical=Sears&BV_UseBVCookie=Yes
or find a thin-walled socket a little to small and pound it on, as AZmkiii said. there's no way there's not enough room.
if there's no room to get a socket around the lug, grab a chisel and start pounding away on that bad boy. eventually you'll crack it.
It may be a "socket" style lugnut that has splines on the inside of the lugnut, not the outside, so the outside sits almost flush with the wheel. The hammer/socket/impact gun is what I do day in/day out on customer's cars, it's very effective. If you're that screwed, get three more keys for your wheel locks and JB weld them on, then bust them off the next day by hand so as to avoid cracking the JB Weld with an impact gun. just be careful you don't JB Weld it to the wheel.
Thnakx everyone for the input. The lugnut is almost flushed with the wheel so U cant put anything over it. I will try the JB weld. Thankx again for the help.
1 - 8 of 8 Posts
