1 - 16 of 16 Posts
http://the-perfect-exposure.blogspot.com/2009/02/m2-motoring-bmw-m3-w-vf-engineering.html
2006 BMW M3
OEM Specifications
Exterior Color: Alpine White
Interior Color: Imola Red Leather
Transmission: 6 Speed Manual
Engine: S54 3.2L I6
Modifications
Exterior
* OEM Euro M3 Front bumper
* Front reflectors deleted
* Ac scnitzer front lip
* Hamann brake ducts custom molded to front bumper
* Seibon Carbon fiber hood
* CF Hamann GTR sideskirts
* Seibon Carbon fiber trunk
* Custom rear diffuser
* Depo Smoked corner lenses
* Black matte front kidney grilles
* Black matte side grilles
Interior
* Recaro Pole Position bucket seats black leather/grey suede
* VAC Floor mounts
* Recaro sliders
* Recaro aluminem side mounts
* Crow 4-point racing harness - red
* Hamann aluminum shift knob
* LeatherZ Imola red w/ black stitch shift boot
* LeatherZ Imola red w/black stitch emergency brake boot
* Bimmian aluminum e-brake handle
* Bimmian aluminum pedal set incl. dead pedal
* Defi BF series boost gauge
* Defi BF series oil pressure gauge
* Innovate Digital Wideband A/F ratio gauge
* Defi control module
* Full custom bolt-on 4pt. roll cage with removable harness bar by Oink Fabrications
* Roll cage custom powder-coated white.
Engine
* VF-Engineering Stage 2 Supercharger system
* GIAC custom tuned stage 2 software
* Top speed governor removed
* Vortech V2 Super Quite SC trim polished supercharger
* Replacement OEM serpentine belt
* Replacement serpentine belt tensioner
* Replacement 8.0-8.5 psi supercharger pulley
* Replacement chargecooler manifold
* Bosch water pump with VF water reservoir system
* VF- CNC machined 6061 aluminum bracket system
* OEM BMW idler pullies
* Replacement fuel pressure regulator
* Stage2/3 OEM High flow spray pattern matched fuel injectors
* VF- Custom molded polypropylene ducting
* VF- Custom tuned supercharger intake
* High flow overrun bypass valve system
* Custom crank case ventilation system
* 4 ply silicon couplers with OEM screw clamps
* VF - CNC oil fittings with high pressure OEM oil lines
* MAF upgrade conversion
* K&N induction filter with cold air intake
* JIC Cross Competition quad-tip SUS exhaust
* JIC Cross Competition section 2 SUS midpipe
* Ki’s Racing Titanium section 1 pipes
* Custom Rogue aluminum Oil cap with senders
* VRS custom black cf engine cover with silver cf center insert
Wheels/Tires/Suspension
* Volk CE28N Time attack 19×8.5, 19×10.5
* Hankook Ventus S1 Evo Tires 245/35-19, 285/30-19
* JIC Cross Competition coilovers
* JIC Cross camber plates
Brakes
* JBT front and rear big brake kit
* JBT 6 Piston front calipers
* JBT 2-piece 355mm slotted rotors front
* JBT 4 Piston rear calipers
* JBT 2-piece 355mm slotted rotors rear
* Stainless Steel brake lines
* Hawk brake pads
Audio
* Memphis Audio M-Class 5.25 components
* Memphis Audio M-Class 6.5 components
* Memphis audio components
* 2 12 Memphis Audio M-Class subwoofers
* 2 Memphis Audio M-Class amplifiers
* Custom Fiberglass subwoofer enclosure painted alpine white, wrapped in Imola red leather
* Custom Plexi-glass Amp rack wrapped in imola red leather
* White LED lights to illuminate amp rack and subs
* All gray trunk lining dyed blackTrunk Wrapped in red leather
* Memphis Car Audio Tweeters with cross-over
* Complete Audio system to be done by Autofashion USA
Moderator
The only thing Time Attack about this are the wheels
Come on guys. The white LEDs' to light the amp rack have to be worth a couple of seconds each. You know, when it is foggy, they are like lasers.
used to be member 66
Gotta admit its got to much "show" but looks way better than the HPF monstrosity that was on here.
Stock E46 M3 bodies look sooo great, I hate when anyone touches them (except for CSL truck spoiler). Kind of like how Supras should retain stock bodies, maybe except for the RMM (think thats what it is) chin spoiler and maybe RMM wing.
1 - 16 of 16 Posts
