1 - 14 of 14 Posts
I've been digging through trying to find a write up on EVERYTHING that's invovled in deleted the MAF and going to a MAP. I know you can do it with AEM but I'm really looking for the simplest way. Is there a block for the MAP sensor? What electronics do you use? I know the VPC is discontinued now so what else is there? Did I miss a sticky somewhere? This seems like it would be an easy to find topic as I still haven't run into anybody who'd rather have their MAF than a MAP system.
about the simplest way to convert from MAF to MAP is to get a MAP ECU
no not exactly- how does just wiring in a piggyback ECU allow you to have a MAP system? How does it get a reading of manifold pressure without having a MAP sensor actually tapped into the intake manifold?
Discussion Starter #6
AWESOME man thanks that's exactly what I'm looking for. Where do you usually run the vacuum from? (stock GTE intake manifold)
Mine it tied into the back of the intake manifold ...I forget what was there but it was removed, maybe EGR related though not sure now.
Boost4fun
I used the BOV line to t it in. It´s back at the firewall and worked great for me.
Boost Junkie
The best thing to do is to use some aluminum or stainless brake line and use as little vacuum line as possible for this line.
Steve
The Don of SF!!!
VPC or MAP .... personally i say go with the VPC
1 - 14 of 14 Posts
