·Ok I just installed head gasket (FelPro stocker) torqued to 60ft-lbs, anyway its using water and heating up, if it sits and idles its fine but when you take off the temp gauge starts heading up then falls back down it is using about 1 cup of water per 100 miles. What could be wrong with this thing? Also the turbo cuts off at 9psi, is that normal? This car is bone stock with a boost controller, turbo timer and aftermarket blowoff valve.
