F
fitchbuck
·Guest
Just got a TurboXS standard mbc, looks quality.
Do I install it between the vsv and brass actuator, as was my bleeder T previously?
Or is it done as follows:
remove hose from vsv to wastegate;
cap vsv and wastegate nipples;
install MBC between the nipple on the 1st turbo compressor and the input to the watsegate actuator.
Intuitively it seems like it should work in the same position as the bleeder T, but I saw this other install method noted above in a previous thread.
The TurboXS instructions state to install it on the hose between the positive pressure side of the turbo to the wastegate actuator.
