1 - 4 of 4 Posts
Just picked one up with no instructions. Right now i have it hooked up the following way one hose from controller to wastegate and the other hose fron the other nipple to the turbo. this should work right or do i have to use the t fitting
Is it a ball and spring type? If so, the port on the underside of the ball and seat is for the pressure source and the port above the ball is for the wastegate.
BMM
the lines have to be a certain way. so if you try it and it doesn work. switch them. turn it in a little, check your boost gauge. and if its not where you want it, turn it in a little more.
1 - 4 of 4 Posts
