1 - 4 of 4 Posts
I use rpm to activate the methanol but it's the same procedure.
Open the program.
Load your map.
Goto edit.
Click ecu configuation.
Select "PSI" under switched output. There are two. Switched 1 & 2. Select the one corresponding to the wire you used.
Type in desired pressure in the pressure switch block.
Save your file and upload to the map ecu.
It's all in the map ecu manual btw.
1 - 4 of 4 Posts
