1 - 3 of 3 Posts
I just installed my new map-ecu 3 and i was wondering is it possible to wire up the launch control feature to the stock clutch pedal switch? Has anyone done this, or how else should i wire it up.
I have the switch disabled right now so i can start the car without depressing it.
Hardtopper
I can't help you with the MAP ECU setup as I'm using the Rush Racing Anti-lag, but using the stock clutch switch doesn't work that well because you come off of the switch and disable the 2-step before the clutch is engaged. I went to Radio Shack and bought a pack of 4 (not available individually) Normally-Closed momentary switches for $4 and fabbed a bracket with a piece of aluminum and hung it off the cruise control disable switch at the top of the pedal. This way the 2-step is engaged until the clutch pedal is fully released.
1 - 3 of 3 Posts
