·I couldn't find any previous info on this, but thought I'd read about it somewhere. Last Sunday at the local track, which is nasty on brakes, I started seeing brake fluid drips around the master cylinder area. I've never seen this before. My brake temps were pretty high, I'm sure. I have an IR pyrometer which pegs at 900F and the front rotors were hotter than that. The brakes were great other than a slightly lower pedal when hot, which was due to stock brake lines, I think. I'm using Motul fluid and didn't have any boiling or other problems. Master cylinder fluid level went down about 3/32 inch over the course of the day. On another note, what are you guys using for power steering fluid? Thanks, Jeff
